'sendCmd('save "' + playlistname + '"')' return? (Solved)
Postby irishwill2008 » 30 Nov 2016, 18:14
irishwill2008
Re: What does 'sendCmd('save "' + playlistname + '"')' retur
Postby surfninja » 01 Dec 2016, 16:41
I don't know python but a quick google found .
you might want to check if the playlist exists before calling sendCmd to create a new list.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby irishwill2008 » 01 Dec 2016, 17:02
SurfNinja, didnt think of that! What a great idea xD Will give that a shot, i could use some JS to check if it exists or not anyway ;) Great call on the file check!
I was just doing a simple fail / success check guessing the system knows it encounters the issue - failing the command but honestly dont know what it returns so..
Thanks!
irishwill2008
Postby hondagx35 » 01 Dec 2016, 22:49
Postby surfninja » 02 Dec 2016, 16:30
Frank, your example is very, very good. Danke! It is always good to know that how the asynchronous communications work through mpc (mpd's client) and not through the file system.
surfninja
