Which DAC and Case
Which DAC and Case
Postby Pete » 20 Dec 2018, 00:55
Just bought myself a Pi 3B+
Which HAT DAC do you guys recommend as as a case that includes pre cut holes for the DAC audio outputs.
Thanks in advance guys
Pete
Re: Which DAC and Case
Postby Ears of Tin » 20 Dec 2018, 03:54
I use this case with the hifiberry DAC+. I didn't need anything pretty because the setup is behind a video screen most of the time.
https://www.hifiberry.com/shop/cases/hi ... -caseplus/
Ears of Tin
Postby Pete » 20 Dec 2018, 10:56
Thank you. Looks nice.
Do all the hifiberry DACs have the same audio output physical locations so interchangeable with cases?
Pete
Postby Ears of Tin » 21 Dec 2018, 02:33
The case will accomodate the RCA style and the digi+ style DACs. I can say from experience that it doesn't fit the Amp2 but it was easily modified with a hobby knife.
Ears of Tin
Postby Pete » 21 Dec 2018, 10:38
Thank you. Better place my order :)
Pete
