Wi-Fi Connection Issues
Postby disco-very » 19 Aug 2016, 16:04
Raspberry Pi 3
Hifiberry Amp+
RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB
Bought the Pi 3 and Hifiberry, put it together, downloaded the Runeaudio .img, wrote it to SD, plugged it in, fired it up.
Pi is connected to the network via LAN cable with HDMI out to monitor.
Everything works as it should, can connect to the UI via a browser on my PC and via the Android app via Wi-Fi on my HTC phone.
However, the Pi will not connect to my Wi-Fi
I can enter the SSID and password, both copy/pasted and manually, and the UI can see my router and report signal strength.
I press connect and : Status: X no network connected.
I have 2 phones, three tablets and two TVs connected to my Wi-Fi no problem.
I have no problem someone shouting 'user error' either, wouldn't be the first time :)
Now stuck, any suggestions? Thank you in advance :)
disco-very
Re: Wi-Fi Connection Issues
Postby disco-very » 19 Aug 2016, 20:16
Well, I installed volumio and that connected to my LAN first time, I was able to operate the Pi over wifi via my tablet and phone proving that the Pi 3 isn't faulty and neither is my router/wi-fi.
I'll reinstall runeaudio in the am, start over and see where I get.
BTW I did rtfm and stfw but runeaudio isn't saving my wifi settings and isn't connecting to my router :(
disco-very
Postby hondagx35 » 19 Aug 2016, 22:32
Hi disco-very,
please try this:
- on the network page click on the wlan0 entry
- wait until the scan has finished
- click on your routers SSID
- enter passphrase (do not hit enter)
- scroll down to DHCP/static and select static
- scroll down and check if there are field marked red
- if so, enter 0.0.0.0 (the field should be turn green)
- go back up and select again DHCP
- click save
Sometimes these fields do not have default values and so saving is not possible.
We have to fix this with next release.
Postby disco-very » 20 Aug 2016, 07:47
Thank you for your answer Frank, I'll try that later and let you know how I get on.
disco-very
Postby disco-very » 20 Aug 2016, 13:41
disco-very
Postby hondagx35 » 20 Aug 2016, 14:06
Postby disco-very » 20 Aug 2016, 19:46
disco-very
Postby hondagx35 » 20 Aug 2016, 21:03
Postby disco-very » 24 Aug 2016, 09:24
disco-very
Postby hondagx35 » 24 Aug 2016, 10:36
Users browsing this forum: No registered users and 34 guests
