wifi connection drops
Postby giovilux » 01 Nov 2017, 13:25
Hi all,
I haven't been able to find a solution here in the forum.
Rueneaudio drops the wifi connection after a while its switched on.
The system doesn't stop playing what is in the play list, it just drops the connection, it is not even visible among the modem connected devices , so the only way to connect to it it's switch it off and switch it on again.
Any ideas?
thanks
Giovanni
giovilux
Re: wifi connection drops
Postby hondagx35 » 01 Nov 2017, 20:02
Postby giovilux » 02 Nov 2017, 08:09
giovilux
Postby hondagx35 » 02 Nov 2017, 10:54
Hi Giovanni,
the internal wifi (Pi3) is not the best at all.
I first would try to move the Pi closer to your router.
If the problem doesn't disappear I would try to use a USB dongle (one that is known to work with Arch Linux) instead.
You also can try my latest test image from , it uses a more recent kernel.
Postby giovilux » 11 Nov 2017, 08:55
Thanks, it's much more stable now.
Giovanni
giovilux
Postby dragos_nedelcu » 28 Nov 2017, 07:24
More stable with dongle or 0.4 beta?
dragos_nedelcu
Postby giovilux » 08 Dec 2017, 15:50
04 beta
giovilux
Postby dragos_nedelcu » 10 Dec 2017, 07:10
I have 04b and it still drops after 20 min
dragos_nedelcu
Postby dragos_nedelcu » 11 Dec 2017, 06:49
Solved it. With a router that i transformed in bridge. Now it is wired and it never drops.
dragos_nedelcu
