WiFi disable RPi3
Re: WiFi disable RPi3
Postby piero » 02 Jan 2020, 11:17
Yes
I followed the procedure.
With root user I modified the file, saved
Executed reboot
When the system restarts
I find the file restored to the original and the wifi active
piero
Postby AndyF » 02 Jan 2020, 12:13
AndyF
Postby piero » 02 Jan 2020, 13:26
Same strange behavior
After the reboot the modified files are restored
I'm starting to think about a problem with the memory card
piero
Postby R101 » 02 Jan 2020, 13:51
Have you re-opened the files after saving, to check the changes have really been saved?
Postby piero » 02 Jan 2020, 19:25
Yes
I also made a backup of the original file
cp disable_rpi3_wifi_bt.conf disable_rpi3_wifi_bt.conf.orig
After reboot the conf file has lost the changes, and the orig file has been deleted
Thank you very much for your interest!
piero
Postby R101 » 02 Jan 2020, 22:27
How are you making these changes? Are you using ssh and nano, or putting the SD card in another computer?
I think there is software that recognises .orig files, so it might be safer to use something else - or just remember that every line started with a #. Otherwise, it looks almost as if your files are being restored from a backup, somehow.
Postby piero » 03 Jan 2020, 12:09
I used an ssh client
Since I installed runeaudio the only changes I have made concern the addition of webradio and the configurations to use the digi+ card
https://www.raspberrypi.org/forums/view ... p?t=193917
https://www.raspberrypi.org/forums/view ... hp?t=21330
piero
Users browsing this forum: Baidu [Spider] and 2 guests
