WiFi disable RPi3
WiFi disable RPi3
Postby DomieMic65 » 12 Feb 2017, 21:09
My first post here!
Hi to all and congratulations for your great distribution!
Is there a way to completely shut down the wifi module of the raspberry pi 3?
Thnx in advance!
DomieMic65
Re: WiFi disable RPi3
Postby hondagx35 » 13 Feb 2017, 00:25
Postby DomieMic65 » 13 Feb 2017, 08:59
Thank you very much Frank!!
I will try this evening!!
Sent from my Nexus 5X
DomieMic65
Postby DomieMic65 » 14 Feb 2017, 16:16
It worked just fine!!!!
Thank you very much!!!!
DomieMic65
Postby n8dgr84 » 23 Mar 2017, 10:22
How do I access this file to edit?
I've created it on the sd card but to no avail.
n8dgr84
Postby DomieMic65 » 23 Mar 2017, 10:30
DomieMic65
Postby n8dgr84 » 23 Mar 2017, 13:21
Ok I downloaded WinSCP.
Found RuneAudio IP
Login using standard ports
Login is "root"
PW is "rune"
Add code to the file as above.
n8dgr84
Postby hondagx35 » 23 Mar 2017, 13:34
Postby piero » 01 Jan 2020, 18:13
Hello
I'm hanging on to this post even though it's old
I would like to disable the wifi, I did the procedure above, but once I do the Reboot it restores the whole folder without the changes made and the wifi remains active.
Any ideas?
Raspberry pi 3 + runeaudio 0.4(beta 20160323)
piero
Postby R101 » 01 Jan 2020, 19:39
piero,
Changing the content of /etc/modprobe.d/disable_rpi3_wifi_bt.conf to:
##wifi
blacklist brcmfmac
blacklist brcmutil
##bt
blacklist btbcm
blacklist hci_uart
will disable wifi and bluetooth.
Users browsing this forum: Baidu [Spider] and 2 guests
