WiFi on RP2/RP3 Unfriendly Router
Postby Perran » 30 Dec 2017, 04:40
A bit confused and frustrated !
Background :
I have got one RP2 with a HiFiBerry
DAC+ and one RP3 with a HiFiBerry Digi+.
They booth operated flawlessly in my old home.
In my new home, none of them gets network connection.
I am not allowed to access the ISP router, locked out.
(I am in Manila !)
I have worked for almost 4 full days with this problem with no progress at all.
The RPs are not visible on the network (Advanced IP Scanner, NMAP and similar).
What I did :
I did not manage to SSH, because I have no IP to RP !
I have downloaded the latest distro, reprogrammed the SD memory.
I even tried to set up a separate network with an unused D-LINK router, no progress (setting up an AP with WiFi).
When I connect the RP HDMI output to a TV, I can see the RPs are booting.
First the coloured square, then the RuneAudio login screen.
After a timeout, the RuneAudio UI is displayed.
I can not manage the UI using an old Microsoft USB mouse (I have 2 of them).
Only occassionaly I can success to access a funtion.
I hope I can solve my problem by getting a proper mouse.
Considering buying a combo with keyboard using WiFi or Blutooth via a dongle.
If I can manage the UI, I can set the Internet to WiFi and enter SSID and Key
for my home network, and I am hopefully done !
There are a LOT of units here connected to the WiFi, cellphones, laptops and TV,
so there should not be a problem with the WiFi network.
May be there is something I have foreseen ?
Thanks a lot
Perran
Re: WiFi on RP2/RP3 Unfriendly Router
Postby hondagx35 » 30 Dec 2017, 12:05
Postby janui » 30 Dec 2017, 12:17
Postby Perran » 30 Dec 2017, 16:05
Perran
