Wifi problem - Ralink MT7601U dongle
Postby goldenyears » 25 Apr 2016, 22:14
Hi all,
I am having trouble setting up wifi on my pi using the runeaudio img file provided by iqaudio. It isn't showing up under the network section using the runeaudio UI - only ETHO. Everything is working great using a wired connection but I really need to get the wifi working as my main system is far from the router.
May I add that I am a complete novice and am trying to learn by reading various posts on this forum. I have installed putty.exe on my computer and using the lsusb command the dongle is showing.
I've tried to copy the debug info but it exceeds the character limit - is there any particular part that would be useful to diagnose the problem?
Thanks in advance,
Al
goldenyears
Re: Wifi problem - Ralink MT7601U dongle
Postby hondagx35 » 25 Apr 2016, 22:30
Postby goldenyears » 26 Apr 2016, 15:36
Thanks for your reply. Here's the link:
http://pastebin.com/tfcK0zJA
Cheers,
Al
goldenyears
Postby hondagx35 » 26 Apr 2016, 16:45
Postby goldenyears » 26 Apr 2016, 16:48
Thanks again for your reply Frank. So would the simplest solution be to buy another dongle? If so what would be the best option?
If I decided to download the new image file would I then download the bin file using the complete command directly onto the pi using ssh command?
goldenyears
Postby hondagx35 » 26 Apr 2016, 17:03
Postby goldenyears » 26 Apr 2016, 17:50
Thanks Frank, I think I'll just buy the dongle you recommended as I'm not confident playing around with commands.
Al
goldenyears
Postby hondagx35 » 26 Apr 2016, 18:00
Postby goldenyears » 26 Apr 2016, 18:56
Is it easy to configure the iqaudio dac once I install the new image file?
goldenyears
Postby hondagx35 » 26 Apr 2016, 23:22
