WIFI problem
WIFI problem
Postby ElTurco » 01 Mar 2017, 14:18
I am new at Raspberry and RuneAudio, already using Rune for 2 days without any problem but today a problem accored.
When Runeaudio plays, I can control from my PC's web browser without any problem but when I open RuneUI app. from my android phone, wifi connection cut off from raspberry and I lost the connection.
I checked from my router that, before ip of Rasp was 192.168.1.5 but today it changes to 192.168.1.3. Anyway when I type 192.168.1.3 on my windows PC browser, no problem. But as soon as I connect RuneUI from android phone, connection is off immediatly.
Here is the log, may be it helps to give some idea
[ 14.981644] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 15.180216] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 15.699042] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 15.699053] brcmfmac: brcmf_add_if: ignore IF event
[ 15.702925] brcmfmac: power management disabled
[ 15.856771] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 15.856790] brcmfmac: brcmf_add_if: ignore IF event
appriciate if someone helps me
Thanks in advance
ElTurco
Re: WIFI problem
Postby hondagx35 » 01 Mar 2017, 14:48
Re: WIFI problem
Postby ElTurco » 01 Mar 2017, 15:15
ElTurco
Re: WIFI problem
Postby ElTurco » 01 Mar 2017, 17:32
Nobody have similar problem ?
ElTurco
Re: WIFI problem
Postby adjax » 20 Mar 2017, 14:43
Are you sure that the settings are correct? You can look and check the settings on this site  Or try to update them. I always check settings here.
adjax
Re: WIFI problem
Postby sysco » 20 Mar 2017, 15:08
sysco
