WIFI wlan0 [no IP assigned]
Postby employee26 » 18 Nov 2016, 14:28
I'm running RPi 2, with EDIMAX wifi dongle. LAN works fine, and cannot connect properly to my wifi Dongle. Can someone help me! :D
###### System info ######
Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
system time: Fri Nov 18 14:26:01 CET 2016
system load: 0.07 0.10 0.06 1/157 1280
employee26
Re: WIFI wlan0 [no IP assigned]
Postby hondagx35 » 18 Nov 2016, 14:51
Postby employee26 » 19 Nov 2016, 03:54
Thanks for instructions
Attached is my debug info
Following the RPi wifi troubleshooting as written exactly, I get to the step where I select my network SSID, enter the password and then select DCHP followed by SAVE.
After I hit SAVE. I shut down the RPi, pull out the ethernet cable and boot and can't connect to http://runeaudio.local as I was able to with ethernet. I plug the ethernet cable back into the RPi, connect and then I check NETWORK.
It shows "X WLAN0 [no IP assigned]
employee26
Postby hondagx35 » 19 Nov 2016, 10:33
Postby employee26 » 19 Nov 2016, 12:27
8-)
That worked! Thank-YOU
employee26
