WinSCP ? help
WinSCP ? help
Postby JrBarco » 22 Jan 2021, 15:31
hello Guys,
i try to log in with winscp. but the pw rune isnt accept its wrong. Putty same result
i have used this
- Use sftp to access files on Rune Audio:
Get WinSCP from here and install it.
When it opens setup the following:
- Session
File Protocol: SCP
Host name: The IP address of your Raspberry Pi
User name: root
Password: rune
but with pw rune i can log in.
is a new clean img that i have instaled rune 6 rune audio1
regards
Jelle
do i have to set something in the rune software
JrBarco
Re: WinSCP ? help
Postby cmh714 » 22 Jan 2021, 16:48
Default root password: ros
Re: WinSCP ? help
Postby JrBarco » 22 Jan 2021, 17:26
tanks
regards
JrBarco
Re: WinSCP ? help
Postby tsawyer » 22 Jan 2021, 20:44
under the 0.4 version, I asked about connecting to the usb drive via winscp and was told the drive would be real-only. I am not sure if that is the case under the latest version but just in case you get a strange message
tsawyer
Re: WinSCP ? help
Postby cmh714 » 22 Jan 2021, 20:54
.4 was a long time ago, but I dont believe that was the case......and remount it rw, you own it! :)
and no, its not ro in current version of rerns
Re: WinSCP ? help
Postby tsawyer » 22 Jan 2021, 21:07
tsawyer
