Wireless network no IP [RESOLVED]
Postby Rintse » 28 Apr 2016, 09:29
Rintse
Re: Wireless network no IP
Postby rastus » 28 Apr 2016, 09:34
rastus
Postby Rintse » 28 Apr 2016, 09:48
Rintse
Postby rastus » 28 Apr 2016, 10:11
Check all IP address settings again, for me, because you like me. And run a ping again, after checking.
"Assigned IP: none" <---- Set the IP address in the Pi for the WiFi manually, type it in yourself. Reboot!
Manually:
IP address
Subnet Mask
Default Gateway
rastus
Postby Rintse » 28 Apr 2016, 10:20
Rintse
Postby rastus » 28 Apr 2016, 10:29
Thank you, I love you too.... you have manually set the IP address in the Pi as 192.168.179.50
But your router is assigning an IP address of 192.168.179.11
Something is amiss here...
And DHCP is enabled (Yes)....
And Autoconfiguration is enabled (Yes)....
From the command prompt run: ping 192.168.179.50
PS: That information (192.168.179.11) is the wifi adapter in your laptop or PC?
rastus
Postby Rintse » 28 Apr 2016, 10:32
Rintse
Postby rastus » 28 Apr 2016, 10:34
Yep, so it's nothing to do with the Pi... my bad.
So this is from the pi? Via SSH?
Type: wireless
Status: connected
Associated SSID: Ziggo89289
Assigned IP: none
Speed: 72 Mb/s
rastus
Postby Rintse » 28 Apr 2016, 10:35
Rintse
Postby rastus » 28 Apr 2016, 10:41
Type: wireless
Status: connected
Assigned IP: none
Speed: 72 Mb/s
Status: connected <----- It's connected to the wireless network, this is good.
Assigned IP: none <----- Looks like you have not assigned a static IP address in the Pi settings (even though you showed me the pic), strange.
Speed: 72 Mb/s <----- There is throughput, mmmm, still strange.
Have you tried 'Auto' instead of 'Static' under IP assignment?
rastus
