Wireless Setup (solved)
Postby PiGuy » 23 Nov 2016, 22:02
Hi -
I'm trying to set up the WiFi on my Pi3B using the Pi inbuilt wireless. It seems to pick-up every wireless device in the neighbourhood
except my router! The router has SSID broadcast enabled, so that isn't the problem. This is with RuneAudio 3.0.4 Beta.
I did wonder whether Rune was smart enough to figure out that the router was already connected (via Ethernet) and thus
didn't bother showing it as a a wireless connection as well? But, this seems at odds with the wireless setup instructions
which pretty much all seem to connect to a router to do the wireless setup.
I can't see a way round this at the moment, so any/all advice/suggestions are appreciated.
PiGuy
Re: Wireless Setup
Postby hondagx35 » 23 Nov 2016, 22:38
Hi PiGuy,
please check the channel your router is set to.
Our current image only can use channels 1 - 11.
With updating the kernel and setting the correct reg domain also channels higher than 11 are usable.
Re: Wireless Setup
Postby PiGuy » 23 Nov 2016, 23:46
Many thanks for the super-fast reply, Frank. :-)
I changed the channel on the router and it worked straight away! Brilliant.
Just listening to some Allman Brothers on headphones into the Pi.
Now - just need to get a DAC.
PiGuy
Re: Wireless Setup (solved)
Postby pete008 » 02 Dec 2016, 19:50
pete008
Postby hondagx35 » 02 Dec 2016, 21:55
Postby pete008 » 02 Dec 2016, 23:35
pete008
Users browsing this forum: Majestic-12 [Bot] and 31 guests
