Wireless
Wireless
Postby anadigi » 18 Aug 2014, 19:48
I have the raspberry pi B+ with 1.3alpha. Everything seems fine until I have the wireless dongle installed.
I can only use wireless while i have wire connected. If I unplug the wired network cable, then the wireless will not work!
If I am using the tablet with the MPDroid cannected, the web UIi will not work neither.
anadigi
Re: Wireless
Postby cmh714 » 18 Aug 2014, 20:24
there are many posts around if you look....for me, I had to down the interface and then use netctl to enable it and make it work to get it into wifi only.
files for netctl are in /etc/netctl/
you need one for wlan0 in there
the general commands are:
ifconfig wlan0 down
netctl enable wlan0
netctl start wlan0
Re: Wireless
Postby anadigi » 18 Aug 2014, 22:44
Thanks for your help!
Do I have to do it again if I restart the Rune?
anadigi
Re: Wireless
Postby cmh714 » 18 Aug 2014, 23:50
it should stick once you get it.
Re: Wireless
Postby anadigi » 19 Aug 2014, 00:20
Thanks again.
I believe there is something difference with raspyfi as I have the raspberry pi version B with raspyfi and the same TP-Link N725 version 1.
I can play with either wireless or wired with no problem.
With this Rune, I cannot use Wifi only. Even I can connect with wifi only, it is dead slow and impossible to use it.
anadigi
Re: Wireless
Postby anadigi » 19 Aug 2014, 00:23
Which I don't understand is I have to plugin both wired and wireless to play normal. Wired only is fine though!
anadigi
Re: Wireless
Postby cmh714 » 19 Aug 2014, 00:43
you need to be plugged in so you can get the wifi working. once working, you can use it unplugged and only on wifi
just takes some effort
Re: Wireless
Postby ACX » 19 Aug 2014, 00:48
You should need wired ethernet connection only the first time to configure your wlan card. After that, once connected to wi-fi, you should be able to unplug the wire and connect to your device using the wlan IP address.
Re: Wireless
Postby anadigi » 19 Aug 2014, 00:57
That is why I post this problem. May be something different with Raspberry B+. As I have mentioned before, I have no problem with the Raspyberry Pi Version B with Raspyfi which I still using.
Hope someone will post the New Raspberry B+ experiment.
anadigi
Re: Wireless
Postby anadigi » 19 Aug 2014, 00:59
anadigi
