Wlan/Wifi Problem with Cubieboard 3/ Cubietruck and Rune 0.3
Cubietruck related support
Postby Guitarfreak » 13 Dec 2015, 16:42
Hello this is Daniel from germany.
I have he following problem:
I use a Cubietruck with build in Wifi and Rune 0.3.
Connection with ethernet is just fine and Rune boots very fast.
But it wont connect to wifi with disconnected LAN.
With connected LAN it finds my network without problems. and when i connect the wifi, it works.
But if i restart or shutdown the cubietruck und disconnect the ethernet - it wont connect to wifi again.
Tried with rune on SD Card, now in the NAND, but same problem.
Any suggestions how to solve the problem?
Thank you
Best regards
Daniel
Guitarfreak
Re: Wlan/Wifi Problem with Cubieboard 3/ Cubietruck and Rune
Postby hondagx35 » 13 Dec 2015, 18:04
Postby JeffD » 15 Dec 2015, 22:51
Du hättest mich richtig froh gemacht! Dankeschön!
That was also my problem! You can forget about my debug post you requested a while a go.
There is also a sound improvement. Losing the Ethernet cable is like removing some jitter?!
Anyway, thank you again.
Regards, Jeff
JeffD
Postby ACX » 20 Dec 2015, 01:10
Postby JeffD » 25 Dec 2015, 22:57
Yes it had. It is a cat6 cable.
Regards, Jeff
JeffD
Postby ACX » 26 Dec 2015, 02:30
Try with a normal patch cable with plastic plugs, if you notice improvements then it was a ground loop issue.
Postby bejoro » 28 Dec 2015, 16:10
Hi Jeff,
I also had ground loop problems.
I solved it by using UTP cable (unshielded twisted pair).
E. g. search for "CAT 6 UTP" on Amazon.
Good luck.
Best regards,
Bernhard
bejoro
Postby floyd » 05 Feb 2016, 22:04
floyd
Postby floyd » 24 Jun 2016, 23:39
floyd
Postby hondagx35 » 26 Jun 2016, 21:46
Return to Cubietruck
