WLan with static IP - how is it possible?
Postby gnom » 04 May 2017, 14:32
Hi there,
i have another problem: I wanna get a static IP for the WLanconnection!
How can i get this. Do i have to change it via Putty? The Ethernet connection is fine, but i cant find the maslk for the IP at the Wlan tab.
Best
Z
gnom
Re: WLan with static IP - how is it possible?
Postby hondagx35 » 04 May 2017, 14:49
which version do you use?
On the wlan tab change IP assignment from DHCP to static and you should be able to enter your IP.
Postby gnom » 04 May 2017, 18:51
I have the version 0.4. when I click on a wlan ssid name I have Noch possibility to choice between dhcp and static. I only can click on "add new profile" and then I have to fill out everything but at the end I can't connect to the wlan...
Best
Z
gnom
Postby gnom » 04 May 2017, 18:57
...strange....after some tries the masks for dhcp/static came up and everything worked fine!
Thanks for your help!
Z
gnom
