Wolfson Audio Card patch for RuneAudio
Re: Wolfson Audio Card patch for RuneAudio
Postby will-1 » 08 Aug 2014, 16:50
will-1
Postby maestro » 16 Aug 2014, 14:50
Thank you Master for the elegant wolfson audio card patch you have shared with us.
It works seamlessly.
I wish to seek your advice on what are the differences between 'Playback_to_Lineout.sh' and 'Playback_to_Lineout.EQ.sh'.
What is the recommended choice between these two.
Thank you.
maestro
Postby johnbanks » 17 Aug 2014, 16:22
Hi ...
I opened each file and looked at the contents.
The ~~~EQ~ version has extra lines to route sound through the equalizer and more lines to adjust the equalizer.
Beyond that I'm lost.
Perhaps an expert like saman on this forum leg can give more advice.
(Incidently, I run Notepad++ (free download) on my Windows machine to view/amend files like this)
johnbanks
Postby maestro » 18 Aug 2014, 01:22
Thank you for the comments.
Perhaps the Master Saman would be able to explain this further.
maestro
Postby maestro » 22 Aug 2014, 15:18
johnbanks,
Kindly advice me whether there is any difference in the quality of the audio output using the 3_12 kernel from using the earlier 3_10 kernel and also the difference in the quality of the audio output using RaspyFi against Volumio 1.41 and RuneAudio 0.2.
Thank you.
maestro
Postby johnbanks » 23 Aug 2014, 17:47
Have no experience of RaspyFi or Volumio - so can't help there.
From the comments on the forum - 0.3 sounds 'better' than 0.2.
Sound quality is subjective and influenced by one's speakers of course. I'm delighted with 0.3 + Wolfson ... have an HD audio track of a fast movement of a Haydn string quartet - it almost takes my breath away with it's realism ... I can almost smell the rosin on the players' bows ... exaggerating to make my point :)
johnbanks
Postby ACX » 23 Aug 2014, 18:33
Postby maestro » 24 Aug 2014, 01:09
Thank you very much for the comments.
maestro
Postby christo » 28 Aug 2014, 01:34
Can anyone point me in the right direction to find info on how to apply this patch?
I have never applied a patch. Can i apply the patch to the 0.3 beta?
Thanks!
christo
Postby Naranj223 » 28 Aug 2014, 09:57
Naranj223
