Wolfson Audio Card patch for RuneAudio
Re: Wolfson Audio Card patch for RuneAudio
Postby theaddies » 30 Jan 2015, 03:52
I am so close to getting my PI and wolfson card to work. I have followed everything included in this post. I have added the scripts to a folder called root/use_case_scripts. I believe all I need to do is execute the script to make the lineout work, but the message I get is that Permission is Denied.
[root@runeaudio use_case_scripts]# ./Playback_to_Lineout.sh
-bash: ./Playback_to_Lineout.sh: Permission denied
or this
[root@runeaudio use_case_scripts]# sudo ./Playback_to_Lineout.sh
-bash: sudo: command not found
I am sure it is something simple but I am a NOOB (duh) and can't figure it out.
Thanks for the help. I was pursuing Volumio but I have made it much much further here. Many thanks for all the awesome work.
theaddies
Postby Naranj223 » 30 Jan 2015, 13:31
Naranj223
Postby theaddies » 30 Jan 2015, 14:33
Wow. Thanks so much. I can't wait to get off work and have a try. Is it necessary to setup the cron job described by johnbanks a few posts up. From what I understand the lineout setting should be remembered by the PI on reboot, but I wasn't sure. Thanks again.
theaddies
Postby Naranj223 » 30 Jan 2015, 15:00
Naranj223
Postby agosine » 10 Feb 2015, 18:02
I am new to Rune Audio, but am very impressed. I am writing here to say thank you for this information. After spending 3 hours trying to figure out why I was not getting any sound I found this thread and everything works beautifully now. Next I need to set up the CRON job so everything works when rebooted.
Will these scripts be included in future builds?
Thank you again.
agosine
Postby ACX » 11 Feb 2015, 01:46
Postby gimesketvirtadieni » 03 Apr 2015, 09:27
Hello
I am using Raspberry B and Wolfson DAC. I can hear slight pops when music is started. Is it normal and other users hear this as well? I tried all possible distro's that support Wolfson (element14 provided distro, Volumio, Runeaudio, OpenElec), the result is the same.
I am out of ideas, so any thought is much appreciated.
gimesketvirtadieni
Postby gimesketvirtadieni » 04 Apr 2015, 09:04
Hello
Short update: I managed to compile new Cirrus Logic 3.18 kernel with Wolfson DAC support:
-> Good news: no pops when music starts!
-> Good news: I have 3.18 kernel which is compatible with B, B+ and B2
-> Bad news: rare pops are present when you stop playing
After tracking these pops these are my findings so far:
-> It is MPD related as I get them only from MPD (bad news for Volumio and Runeaudio)
-> It is codec related as pops for MP3 are more noticeable and happen more frequently
With the following MPD configuration pops happen rarely so they are tolerable, however I keep seeking for perfection ;)
decoder {
plugin "mad"
enabled "no"
decoder {
plugin "ffmpeg"
enabled "yes"
decoder {
plugin "mpg123"
enabled "no"
gimesketvirtadieni
Postby giscot » 12 Apr 2015, 10:23
Hi everybody,
I'm new with runeaudio, I have a raspberry B config with wolfson card...
All is OK with runeaudio UI and NAS attachment but...
It doesnt work, perhaps with a bad Wolfson parameter ? (I'm not confortable with which parameters are the good ones for the card)
Here is my config below,
Thanks in advance !!! :D
Gilles
###### System info ######
Linux version 3.12.13-rt21_wosa (pi@localhost.localdomain) (gcc version 4.7.1 20120402 (prerelease) (crosstool-NG 1.15.2) ) #1 PREEMPT RT Wed Apr 30 17:51:17 CEST 2014
system time: Sun Apr 12 10:11:46 CEST 2015
system load: 0.67 0.70 0.51 2/98 1324
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 481.15MiB 213.30MiB 267.85MiB 11.48MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Sun Apr 12 08:58:32 2015 Load average: 0.67 0.70 0.51 1/100 1326
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k3.12.13-rt21_wosa.
0 [sndrpiwsp ]: snd_rpi_wsp - snd_rpi_wsp
snd_rpi_wsp
1 [ALSA ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
bcm2835 ALSA
PLAYBACK devices: (aplay -l)
card 0: sndrpiwsp [snd_rpi_wsp], device 0: WM5102 AiFi wm5102-aif1-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
PCM devices: (aplay -L)
null
default:CARD=sndrpiwsp
snd_rpi_wsp,
Default Audio Device
sysdefault:CARD=sndrpiwsp
snd_rpi_wsp,
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
sysdefault:CARD=ALSA
###### PHP backend ######
php version: 5.5.17
debug level: 0
Debug data collected in 3.301 seconds.
giscot
Problems: Wolfson Audio Card patch for RuneAudio
Postby runaway » 15 Apr 2015, 15:26
Hello to all, and thanks for all the hard work to get the PI/Wolfson combination to work.
I have a Problem that might be related to me being a Linux-newbie.
I cannot execute the shell-command to make the wolfson play to the lineout: ./root/use_case_scripts/Playback_to_Lineout.sh results in "No such file or directorie". I tried without the point, without /root/, and all combinations. Unfortunately I could not download the manual for the use of the scripts :-(
Here is what I did:
-Install Rune 0.3-beta
-on Windows copied the folder /root/use_case_scripts/ with all the files to root on card
-putty to runeaudio
-type in "/root/use_case_scripts/Playback_to_Lineout.sh" or "./root/use_case_scripts/Playback_to_Lineout.sh" or "sudo /root/use_case_scripts/Playback_to_Lineout.sh" or "sudo ./root/use_case_scripts/Playback_to_Lineout.sh", all resulting in "No such file or directory".
-tried "cd /root/" -> nothing happens
-tried "cd /root/use_case_scripts/"-> Error "No such file or directory".
-tried "cd /use_case_scripts/"-> Error "No such file or directory".
I hope this is not a stupid question, but could someone please tell me what I am doing wrong?
And, a second question: If I get this to work, Do I have to do it again, every time I rebbot? Do I need to create a cronjob fo that?
Thanks again, Stefan
runaway
