Working Airplay with DAC Hifiberry and Soundclouf support
Postby vinh » 09 Apr 2015, 16:34
Hello!
It's would be nice if these features will be part of the next release.
Thanks,
Raspberry Pi Model B + RuneAudio + HifiBerry DAC + SONY CMT-G1NiP
vinh
Re: Working Airplay with DAC Hifiberry and Soundclouf suppor
Postby hondagx35 » 12 Apr 2015, 17:25
Postby J@r0d » 21 Apr 2015, 06:23
I have tested many conv USB/spdif and only hifiberry works fine with airplay, but with same conv i have no problem with volumio, i search a différence with 2 distrib
J@r0d
Postby hondagx35 » 21 Apr 2015, 08:53
Postby J@r0d » 22 Apr 2015, 12:50
With hifibery digi sound is good with airplay and external hdd or nas
With other conv USB>spdif sound is good with external hdd or nas but is distroded with airplay,
With distrib archphil or volumio the sound is good with airplay and conv USB>SPDIF
Tested with other kernel and all profil, but same problem sound is distorded
J@r0d
Postby J@r0d » 24 Apr 2015, 12:37
I have buy RPI 2 and i have tested with two conv USB>Spdif and USB>Aes and same probleme with airplay
I have tested with two ipad mini one on IOS7 and one with IOS8, same problem
J@r0d
Postby hondagx35 » 24 Apr 2015, 23:36
Postby J@r0d » 25 Apr 2015, 07:38
Thanks you, i go test today
But is strange, when i use airplay with hifiberrydigi i have no problem, when i use airplay with interface USB i have problem
J@r0d
Postby J@r0d » 25 Apr 2015, 13:34
J@r0d
Postby J@r0d » 13 May 2015, 13:30
I have many many test and airplay doesn't work with usb convertisser
I change sampl rate 48000 for 44100 same problem
What is the route of audio flux when use airplay ? If i modify sample rate in mdp.conf for 96000 when i play with shairport the sample rate is not affected, when i play a local music in sdcard the sample rate out is 96000, if i modify samplerate in alsa.conf for 48000 or 96000 the sample rate with airplay is 44100 in out
The only condition for use airplay without disortion is when i use digi+
J@r0d
