Works great with Qnktc AB1.2 DAC up to 24/192
Postby dopus » 14 Mar 2014, 08:05
I am playing High Rez files up to 24 bit 192Khz without any problems. But with big files...go into mpd config and choose to buffer 30 % before playing. If u dont do that....it will click a little bit in the sound the first 5 seconds. Also adjust buffer size up a little bit. All in all, with these small tweaks it works great.
dopus
Re: Works great with Qnktc AB1.2 DAC up to 24/192
Postby ACX » 14 Mar 2014, 09:16
Uh, I didn't know this open source DAC (very interesting indeed), thank you for the feedback. Which platform are you using, Rpi or BBB?
Postby dopus » 14 Mar 2014, 15:35
Through usb hub connected to raspberry pi. Usb hub for extra power. The dac is usb powered only so running it through rpi^s usb did pull to much power and the freezed up. With powered usb hub it works great. The dac is open source, its easy to modify, it sounds great for the price, its not expensive,it is async usb ,it supports up to 24 bit/192Khz
www.qnktc.com
dopus
Postby Midnight » 15 Mar 2014, 13:03
Seems this DAC uses a Atmel AVR32 MCU programmed in open source C as USB controller. Interesting and probably a lot of more work than using a hardware USB controller chip.
Midnight
Moderator
Postby dopus » 27 Mar 2014, 12:30
Looks like they have changed the name of the dac to Henry Audio instead of Qnktc. Dont know why...but it is the same dac , and specs. Only new name.
dopus
Postby Nemitor » 09 Dec 2015, 10:41
What do you think about the new Henry Audio?
Do you think that its better than Modi 2 uber?
I do not know what to do :(
Thanks!
Nemitor
Postby GAP » 29 Apr 2016, 06:36
Runeaudio on Raspberry Pi 3 -- Henry Audio DAC -- Primare i21 -- Bowers and Wilkins 685
GAP
Postby hondagx35 » 29 Apr 2016, 17:07
Postby GAP » 30 Apr 2016, 12:56
Thanks Frank!
I bought a 2.5A RPi power supply I will use. And haha, yes with'ordinary' I meant a powered bus. I hope I won't need the hub though.
GAP
Return to Compatibility list
