[Rune Audio] Youtube addon
Postby djsebfr » 07 Mar 2018, 23:07
I also tried to install the Rune Youtube addon and did not get errors during the install process.
It doesn't seem to work for me though :-(
When I paste a song or playlist in the import box I get messages "Added to queue" and "Fetching video", but nothing is actually added to the queue.
Any suggestions of what I'm doing wrong?
Thanks you ;)
Rpi 3
Rune Audio 0.4b
Addon Menu 20180307
djsebfr
Re: [Rune Audio] Youtube addon
Postby elemeledutki » 08 Mar 2018, 16:41
I am facing the same problem - after import and fetch of video/playlist nothing changes (number of entries in the playlist queue doesn't change, cant find the imported content...)
elemeledutki
Postby foldesics » 16 Aug 2018, 13:33
Hello!
Over SSH try to check youtube-dl...
Traceback (most recent call last):
File "/usr/bin/youtube-dl", line 6, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3030, in <module>
@_call_aside
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3014, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3043, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 654, i n _build_master
ws.require(__requires__)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 968, i n require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 854, i n resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'youtube-dl==2018.8.4' distribution was not found and is required by the application
WorkAround:
sudo pacman -S python python-setuptools python-six python-appdirs python-packaging python-pyparsing;
Addons reset, youtube install.
Voila!
foldesics
Postby tuna » 18 Aug 2018, 07:48
python should be installed as a dependancy on youtube-dl, I'll have a look on why that isn't working anymore
tuna
Postby ianhaynes » 02 Oct 2018, 12:18
The YouTube Add On has stopped working for me. Is it working for anyone else?
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby rern » 04 Oct 2018, 08:38
A RuneUI Youtube update by tuna has been ready for awhile but the upcoming RuneUIe will break it. Please be patient.
Postby Toube » 12 Oct 2018, 07:30
Hi guys,
I also added the youtube addon successfully. I can't seem to find the place where to open youtube url in the app?
Where is it supposed to be found?
Regards,
Toube
Toube
Postby Toube » 12 Oct 2018, 07:36
ok so it should be visible in the playlist beside the delete icon. How can I add it there?
-Toube
Toube
Postby Toube » 12 Oct 2018, 08:02
Ok so I updated the addon and now I have the youtube play icon in place :)
But now if add a video it says added to to cue but nothing is added?
EDIT:
It now added a playlist to local storage, but when I open it, it's empty. Or if I try to play it nothing happens. Almost there?
-Toube
Toube
